- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
And I'm kicking my ass now.
It looked really good so I bought it. I unloaded it after picking it up a couple weeks ago. When I went to load it up for our long weekend the jacks started to move a bit so I set it back down on some saw horses that I built years ago [I'll take pics-they will hold a LOT of weight]. Being that I do [did] house renovations I wasn't to worried about tearing it apart to remove the little bit of rotten wood. Well..... It's a lot of rotten wood, Ive already removed the windows, door and the bottom 4' of aluminum skin and the front up to the roof, and it looks like I'll be removing the roof next as the vent has been leaking for a while. The way these are built is not in the same order as a house would be... the roof goes on last! This means that I can't remove the inside panel around the vent without.... you guessed it, removing the roof.
Oh well, back to work,
Richard
PS; I'll post pics later
It looked really good so I bought it. I unloaded it after picking it up a couple weeks ago. When I went to load it up for our long weekend the jacks started to move a bit so I set it back down on some saw horses that I built years ago [I'll take pics-they will hold a LOT of weight]. Being that I do [did] house renovations I wasn't to worried about tearing it apart to remove the little bit of rotten wood. Well..... It's a lot of rotten wood, Ive already removed the windows, door and the bottom 4' of aluminum skin and the front up to the roof, and it looks like I'll be removing the roof next as the vent has been leaking for a while. The way these are built is not in the same order as a house would be... the roof goes on last! This means that I can't remove the inside panel around the vent without.... you guessed it, removing the roof.Oh well, back to work,
Richard
