Both tail lights flash when using left or right turn signal
1998 2.5 Ford Ranger
First of all I change my fuel pump a few days ago.
I removed the bed of the truck to access the fuel pump, unplugged the tail lights
from the rear harness. Put everything back together, but now tail lights act like
hazard lights when I use any turn signal. Also my 3rd brake light flashes when using
turn signal. But it ONLY happens when I turn on the headlight switch.
So during the day everything is fine, until it gets dark I turn on my headlight switch
then both tail lights flash when using turn signals. The head lights work correctly.
check your ground connection.
I like barney... :wub:
