zukirider21
Also known as CIS (continuous injection system). Used on many Porsche's, Volvo's and Volkswagen/Audi vehicles. I was just looking around and stumbled upon this system, and I'm absolutely amazed at what a simple, elegant, foolproof setup this is. For those who are unfamiliar, here's a nice little overview- http://www.volvoclub.org.uk/tech/fuel_injection/k_jetronic2.shtml
Next, I got to thinking. Wouldn't this be a fairly universal system? shouldnt it feed ANY engine (roughly the same size as the injection system was originally intended for) a mixture of fuel and air at the stoichiometric ratio, without any fussing with adjustments or anything? Regardless of where the air's going, it measures it, and pumps out the necessary amount of fuel, right? Sounds good so far, right? Now what if one of those little AFM's isnt enough for what i want? Seems like i should be able to run two afm's, with two sets of injectors (right next to each other). Just think, injection even timing doesnt matter (continuous injection), and the airflow meters would either work in unison (equilibrium), or even if they didnt, with one actuated farther than the other, it should still work out, no?
Okay so now that my confusing fuel injection theory has probably got you thinking, here's what I'm really wondering about. If i were to rig up this system on a ford 2.3t, would it work under boost?? i dont wanna be messing with efi, and finicky blow-thru carbs are out of the question.
I'm really interested because i love simple things, and i think it would be sooo badass to build a lowered 2.3 street ranger with this ingenious system, and a turbo.
