i don't want a 4.0. the gas milage is better with my 2.9, just was curious about the potentials of the 2.9. nothing more than pure curiosity. if i were to go for a bigger motor, it will be a 302. but im content with my 2.9 and when it needs a rebuild, like a stated earlier, im a machinist, maching the motor is not a problema nd won't cost me nothing except the 250 bucks for a rebuild kit. i just want ot refresh the motor and keep on keepin on.
I don't agree that your concern over mileage is grounded in truth
I gotta be honest though I could get PEAK mileage of just over 26mpg with my 2.9 I only did it three or four times.
Generally I drove harder and burned more gas.
On the other hand when I needed to do something hard, towing hauling a load etc the 2.9 turned into a pig.
Hell I once managed to get 12mpg with it.
I have yet to get as bad as 16 with the 4.0.
So yeah it burns more gas out on the highway,
but it's minimum mileage is actually better.
The thing is I am VERY used to my truck (having almost 400,000 miles
in it) and drive the same way I have for over a decade and the 4.0 just doesn't have to work very hard to do the same things.
Just average "knocking around" my 4.0 generally gets 20-ish
And while I could get 21mpg in the same driving wiht the 2.9
I usually didn't
Think of it this way, I spend the bulk of my time during local driving either climbing some 4mile long 12% grade or coasting down such a grade.
the 4.0 climbs those grades relatively easily at 2700rpm
in 4th gear, the 2.9 would do those grades at the same speed, but running at ~4000rpm in 3rd.
For practical purposes I usually backed out of it on the 2.9 and climbed the hills at 3500rpm and a lower road speed.
which engine do you think burns less fuel?
The 4.0 basically goes anywhere I wanna go in 4th at 2600-2700rpm., of course in 3rd revving it out it'll climb those came hills at 85mph while the 2.9 had to struggle to do them at 72mph,
my best effort with the 2.9 on one particular hill... with the 4.0 I actually have to lift to take one corner near the top...
Hey, and that's all with the 4.10 gears I installed to make the 2.9 happy, I'm about to switch to 3.73's
AD
