jesselee20040
Hello,
I have a 87 Bronco II that has been lifted using the stx (high lifter brackets) and a few washers under a set of 2" skyjacker coil springs. It also currently has 31x10.5 tires and I would like just a bit of more clearance. I have been looking at putting a 1" body lift just to give me the clearance. I found some 1" body lift pucks but i dont know how long of bolts I need.
So my question is how long are the stock bolts? It appears that the rubber body bushings and hardware was replaced prior to me buying it, so I would like to just buy longer bolts. Also what is the thread and pitch on the stock bolts?
Any information would be greatly appreciated. Also with me using the high lifter brackets could I install 4" lift springs? It has adjustable camber bushings already.
