Rodango
- Apr 21, 2013
- Automatic
Hey all, on my 1991 XLT Supercab Ranger, started it a week ago and it was spitting gas below, near the gas tank / fuel pump I guess, it was pretty messy underneath with just the ignition on, not even running, so I shut it down.
Jacked onto stands now. Going to replace whatever I can get to that needs it -- shocks, brakes, fuel filter and connector and lines, filler neck (it gets old I've read), tank (depending on condition), maybe more.
I was unable to get the heat shield off from below due to the driveshaft -- bolts are solid on there, even with a breaker bar and penetrating oil. So went to pull the bed: 5 of the 6 bolts came out without much drama, the 6th, closest to the driver's seat is just spinning. The clip it screws into is deep in a beam (box channel? steel frame member?) and blocked on one side by the gas tank...no access on the outboard side or from below.
I guess I have to drill or saw it? Have tried with the T55 bit on a fast electric drill with the bed jacked up to tension the clip, but no joy. I think the clip is rusted to the bolt and just spinning without being held by the metal of the frame; can't even get a screwdriver tip under the washer at the bolt head.
Suggestions?
Also, is this probably the same bolt as later Rangers -- can I get a new bolt and clip from Ford parts or an online source? How would I get the clip into place: is it accessible with the bed off? Hey, thanks for any help - I've already gotten a lot of help from reading the forum!
Suggestions?
