Bolt spec for rear leaf springs and hangers on 2000 4WD
Bronco Ron
Corbin
KY - USA
Other
1975 Ford Bronco
Vehicle
Drive
2”
Total Drop
31x10.50
I need new bolts for the rear leaf springs and hangers. I am having trouble finding them. Can anyone give me the specs? Are the the same ones used on F150?
Stock is a metric bolt, but I don’t remember the size. I changed to Explorer leafs and put poly bushings in my green 00 Ranger and the bushings took 9/16” bolts, I used grade 8 and I think they were 3.5” long.
Also, 4x4 F-150s do not use the same bolts. Not sure about the 2wd ones, but my 95 uses a 3” wide leaf and I want to say the front bolt might be 5/8” grade 8. 2wd F-150s should use a 2.5” wide spring like the Ranger, but bolt size may be larger. Never owned a 2wd F-150.
Try your local spring shop...
Spend a few bucks with a local small business. They'll know what you need and will appreciate the business.
