88ranger5speed
I got some prothane body mounts and soon realized the hole in the middle was very large for the bolt i had with my body lift kit...after some research i seen the "hardware" you needed...so i did some more research and discovered 120$ for the "hardware...So i made my own solution and need some opinions...i got 3/4 inch pipe and fender washers...the bolt is a little loose in the pipe, would that matter with the weight of the cab+ the body lift blocks or any other suggestions?
