Body mount replacement
CreepyCrawler
NCMillwright
Wilmington, NC
it is what it is
Does anybody offer body mount replacements for the smaller mounts? Ive seen the cab corner mounts but i need 2 very far front mounts. Or would that be something id have to cut and drill off another vehicle/ or make?
Front mounts as in the radiator area? Or the front cab mounts?
Just so people know which direction to go.
S-
I ordered a full set for the '92 extended cab and that included the 2 fronts to the outside of the radiator. I think I got them from Rock Auto.
What car? Ranger? Explorer? You got to give deets. But based on you saying rear cab mounts are easy to come by, going to guess you mean a ranger. Just bought a pair of rear cabs myself.
You may have to befriend a welder and see if he can fab you some front mounts. Consult the Haynes Manual for your car to see what they need to include to work.
Sent from my MotoG3 using Tapatalk
I bought all six cab mounts and hardware from LMC.
91 ranger ex cab stx. The front mount under the radiator. Ive ordered all new mount bushings but i need the actual steel mounts
Now that you say this...my two mounts in the front are loose af. Ik can jiggle it and its metal on metal clang.
But hey...it still functions.
Mine...lol
The steel mount welded to your frame why does nobody carry these? I dont have a welder. So i suppose ill just cut one off another truck
Get one made. Why spend to ruin a rusted mount off another truck, when you can just make a fabricate one to work just as well, and last longer than the frame itself?
Just find a local mechanic and ask if they know any good fabricator that doesn't charge a fortune. They will make you one up to inspection spec.
