body mount hardware?
bert296
UP MAINE
anyone know where i can buy new body mount hardware the big washer and sleave thing that goes up through the mount and the retainer piece on top washers and bolts i need pretty much everything other than the rubber mount ive got new poly ones.. is ther a kit some where i can buy all this?? i did find it all on LMC but its $200+
LMC would be my only guess...
can you not just find bolts, washers, and stuff and make your own kit? i've got hardware stores around here that i could probably find all that at... or even the junkyard (but then again, i'm in the south...we don't get rusted rigs like yall).
I'd go to local hardware store with all the old stuff. Match it up and go.
Also any lowes or home depot would have what you need.
Just make sure they are grade 8 bolts...do not use anything less...
I went to a Brafasco store in town...not sure if they have them down your way but they had everything I needed...even longer bolts for a body lift if I wanted...but had to go to Ford for the rubbers...and they were not cheap...found out later about other sources (of course)...
