Body Mount Bushings- 97 vs 99
Rex2nr
Rochester, NY
I have a 1999 Supercab and need to replace the radiator support bushings. I am replacing my radiator support now and would like to just cut the old bolts because of the rust.
I've been checking all over the web and can not find anything. LMC lists them but doesn't have them in stock. I'm not against urethane, but I can not find them for a 98-00, just up to 1997. What is the difference? Can these be used on a 1999?
I am not looking to do a body lift, and if I do, I would like to keep it to a minimum.
Thanks!
Bump
Found 98+ urethane mounts which are 180. 93-97 urethane bushings are 60. Is there a difference dimensionally?
I got the upper half of the original to work for the time being but would like to fix it right as soon as possible.
