Body lift
LearjetMinako
Moore, OK
No, not that kind of body lift.:D The other kind that is required to have better access to the fuel tank. Guess no Ranger is immune to the gas tank filler neck hose cracking up and leaking fuel. Job took me 3 hours to do. Only becuase I had extra work to do with the CB wiring and issues with the new filler neck hose. In the end, I ended up using the original filling port with the new hose. Filled up the tank today, no leaks. Also got to take a sneak peak inside the fuel tank and fuel pump, they are both all clean and nothing weird floating inside.
