Body Lift Question
92MiniMonster
Baltimore
Im in the middle of putting my suspension and body lift on my 92 ranger. I started with the Body lift first. Its a performance accessories kit through Rough Country, in the directions it says to use the " kit bolt, kist washer, and kit nylock nut (1/2"). Only problem is that i dont have that nut. Anyone else encounter this. Im just wondering if im supposed to use those factory clips that slide over the frame?? Any help will be great. Only reason i ask here is because tech. desk is closed.
Thanks,
Shawn
Thanks,
Shawn
yes they want you to use the factory clips that slide over the frame, i had thought that was odd myself aswell, back when i ordered the body lift for my old 87 (ext cab 4x4) it had come with nuts for the bottom side, however this one came with no such nuts so i had to be EXTREMELY carefull not to break any of fords wonderfull speed clips.....
Sounds good, two of my bolts broke off in those clips, so i think i might just put a nut on those two. Not much else i can do about it. O well, itll still work, thanks,
Shawn
