Hey guys, I am wondering if a 6" Body lift would work. Would it cause alot of body rock or would it be ok? Please let me know asap. I plan on doing it by just doubling up some 3" spacers from a body kit. Thanks
a body lift over 3 inches isn't safe, thats why no one makes one over 3inches. cause the bolts that are holding the body to the frame are too long and can break once you get over 3inches cause of weight transfer in corners and stuff like that. the cheapest way to get near 6 inches of lift for cheap would to do add a leafs in the rear and coil spacers up front for 2inches of lift and then do a 3 inch body lift.
I was thinking about cranking up my torsion bars all the way up and adding a 3" body lift but if I do the 3" all the way around and crank the T-Bars then would the front be higher than the rear? and if so what do I need to , to the rear to make it level to the front? also if I did that what size tire would you recommend? sorry for all the questions thank you for any input
it should be level with the t bars cranked and a 3 inch body lift and i would go with 33/12.50. they would look quite nice altho make sure you are geared right for that size of tires because if not you will lose alot of power and mpg's
For
