RangerJ
1987 4x4 2.9 5 spd man trans,139,000 on the clock.At idle and accelleration blue smoke comes out the tailpipes. Will an additive help this, can't afford real repairs at this time. Thanks
Please dont tell me you put Full Synthetic on that many miles on the motor. stick with dino oil (conventional) since it's thicker. best thing for you to do is:
-dave
Thanks for your reply, I did not mention synthetic oil in any of my post I only use dino So I do not know where this came from/ I only ask for tips and I added Restore only. I use 10w40 Valvoline hm. ThanksFull synthetic will not harm any motor, no matter what the mileage is. What do you think will happen if he puts synthetic in?
Conventionals are not thicker than synthetics, that's what viscosity ratings are for. A 5w30 is a 5w30, doesn't matter if it's conventional or synthetic. A 10w30 is a 10w30, a 5w20 is a 5w20, etc.
To RangerJ: I don't recommend using a synthetic, simply because you're burning so much oil, it won't better your situation, and it wouldn't be worth the added expense. But nothing bad would happen if you did use it.
