- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Automatic
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
So I ordered new belts for the ‘79 C101 wheel horse, engine to transmission and engine to rear tiller belt. the transmission belt is a 5/8” and the tiller belt is 1/2”. put them on and they dont work well, seems like they dont work well, Im not sure if they need broke in a bit or if I should just of gotten the regular black belts. The transmission belt doesnt seem to have enough slack when the clutch was pushed in , have to stand on the brake to stop it and shut it off completely to change gears . The tiller on the other hand works fine until you drop it in the ground then its slipping somehow. Before all this the tiller was fine, belt just looked bad, very worn. transmission belt would slip bad , esp in higher gears or if I used the front hitch to move a trailer. I looked up the sizes in several places before I ordered, went with the blue kevlar just because I thought they would last longer, but they seem much stiffer.
