njdriver02
- Nov 19, 2009
- 2.3 EcoBoost
- Automatic
Downshifted into first going too fast
Motor over revved, (over rev code) think that the old oil filter gasket gave from oil pressure spraying oil around the left side of the engine bay on the wires and causing the misfire, and or floated a valve and bent it, plugs fowled in cylinder two and others were nasty from the oil and I kept driving to limp to the shop, misfire/ unburnt fuel scaved the cylinder wall?, rings are done? i think.
,blow by now happening out of dip stick, tried miracle oil overnite in the cylinder, changed all plugs
have not checked compression yet.
Thoughts as to what happened?
