blew a head gasket the other day. so much smoke i couldnt see through it. tore it down to the block in 2.5 hours. rebuilt with all new gaskets in another 4. now when i first start it up (most of the time) it has an awful skip. i figured it was a bad plug from trying to burn coolant but after putting new plugs in it seems a little worse. here's the weird part.
once i start driving, like 30 seconds, it clears up and will run fine untill you shut it down. if you restart right away it skips a little but not bad. if you wait a few minutes its bad again.
what do you think is wrong? bad injector? bad new plug?
