holderd
- May 11, 2011
- Automatic
2000 3.0 Flex Fuel
Engine quit on interstate. Found water in oil and water soaked air filter. Did not overheat. Assumed blown head gasket. Removed both heads and had them overhauled. Reinstalled with new head bolts and proper torque to yield. Cranked up, looked good. Ran down the road about a mile and the same thing happened again. Assumed I screwed up a gasket. Removed heads again, reassembled with new gaskets. Cranked engine and ran a moment. Removed drain plug and oil and water came out. Put water hose in radiator and water flowed straight out of the oil drain. Before I remove heads again, is there any way to determine where this coolant leak is? I wonder if the shop missed a crack in one of the heads? I'm a helicopter mechanic, so I'm not completely without a clue, but this has me puzzled. Help appreciated.
