Tractor Dan
Here is what's going on. I drive into town the other night and notice the blower motor isn't moving much air as in i can hardly feel it coming out of the dash. I tried all positions of the switch and got nothing out of low, the motor runs on medium and medium high but not that fast, and then on high it runs but not much faster than the previous two settings. So far i have checked the resistor pack in the heater box. Checked resistance and all resistors had resistance. So i put it back together. Was gonna drive it tonight and turn the blower on and i'm getting almost no air out of the vents but i can hear the motor spinning just really slow.
So my question is what should i look at next the switch or the motor? I know the motor is easy once i get the airbox out of the way simply apply 12V and give the motor a ground and if it spins up the motor is good. If not replace it. I'm half tempted to replace the resistor pack simply because it's relatively inexpensive and seems to be a common failure. I'm guessing mine is as old as the truck or atleast fairly old because when i unhooked the wire cluster plugged into it a bunch of dust from corrosion fell out from the connector and part.
Also if i test the switch how do i get out of the dashboard? I haven't had a 94 dash apart. My 97 was easy simply removing the bezel and then had i wanted to pull the HVAC controls a few screws was all it took.
Any help is appreciated trying to get this straightened out before i head back to school next week. I finally got heat in it after replacing a bad thermostat.
