Basilius
- Aug 1, 2019
- USA
- 2.5 (4 Cylinder)
I recently replaced my heater core, so I needed to remove the blower motor housing in the engine bay and the entire front dashboard (instrument panel) in the cab. I wasn't careful when I removed the front dashboard and the lines with the yellow connector disconnected from something, and I don't know how or where it reattaches. I think that it reattaches to the circled part on the blower motor housing but I’m not sure.
There are two tubes inside the yellow connector, one hollow tube with a plastic sleeve and one solid tube with no plastic sleeve (see pictures). I tried connecting the tubes to the circled part on the blower motor housing, but they didn’t seem to fit. Where do these lines reconnect, and was there also a plastic sleeve on the solid tube that might have gotten lost when it was disconnected? Thanks
Blower Motor Housing Surface-to-Firewall - Line Connection (close).jpg150.6 KB · Views: 113
Blower Motor Housing Surface-to-Firewall - Line Connection (far - edit).jpg185.8 KB · Views: 108
Blower Motor Housing-to-Firewall Line Connection (far-edit).jpg188.8 KB · Views: 126
Blower Motor Housing-to-Firewall Line Connection (Straight On-edit).jpg150.7 KB · Views: 117
Blower Motor Housing-to-Firewall Line Connection (top down) 2-edit.jpg124.4 KB · Views: 114
Blower Motor Housing-to-Firewall Line Connection (top down).jpg166 KB · Views: 121
