whoy210
Are any of these 3.0s prone to cracking? I recently bought an 02, It started running hot on me, there was just pure water in the radiator, and what i thought at first was just rust in it, now I believe it was some type of block sealer they were using. I flushed it , changed the thermostat and it seemed okay for a bit, but it was using some coolant and had to refill it a couple of times, then shortly after it started running like crap and then i found I had water in the oil. So I pulled the heads, and one of the gaskets was blown around one of the water jackets, but I still went ahead and took the heads to the machine shop and they checked out okay,but after reassembly, I went to change the oil the first time and again the oil pan was full of water. I can't imagine It blew another gasket, Just wondering how prone these blocks are to cracking.
