Blinker issue.
TwistedSmitty
Graham WA
Hey guys need a little help. On my 89 ranger my right blinker quit blinking. The left one still blinks and it flashes when you turn on the hazards. I replaced the bulb to see if that was it and it didn't change. Need your help. Let me know if this is in the right section. Thanks in advance.
Smitty
Must..............not...........................post!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Noooooooooooooooooooo................................nooooooooooooooooooooo.
Aaaaaauuuuuuuugggggggghhhhhhhh........................................................
Check your connector on the side that is not working. Might be rusted out, bad connection, broken wire.
Also check the connector under the bed for a loose wire. Flasher could also be the problem
I will check the flasher. Seem to be flashing a little slow on the good side. Then will try a wiggle test on the wires.:icon_thumby:
