cocoasranger
Almost finished with my A4LD to M5OD R-1 swap. Trying to bleed clutch master with little success. Have new release bearing and slave cylinder in bell housing. Am using used clutch master, reservoir and line.
Tried gravity bleeding and got a thin steady stream out the bleeder, but no pedal after closing it. then unbolted the master and turned it downward and gravity bled with same results.
Could my used clutch master be shoot or is there another method to try? The posts on what to do after unbolting the master and turning it down seemed a little vague, but that might just be me.
