macx
- Oct 21, 2011
I put new shoes on the back axle, then started the bleeding process.
I just bought the truck as a backup, lots of things had been neglected.
Brake fluid very dark, but brakes seemed to work fine.
I've got a brake vacuum bleeder, but can't draw any of the old fluid out.
Actually, got maybe 1/4 cup but now I can't get any more. Just needed
new shoes / pads and fresh fluid.
Have 20+" of vacuum on it and nothing's coming out. I've also tried
leaving vacuum on it and pumping the pedal and that doesn't work either.
Looked in my manual, seems to indicate the brakes can be bled in the
normal manual way - after they describe how to bleed the master cyl
and the ABS valve but then they discuss manually bleeding the wheel
cylinders and don't seem to indicate anything has to be done other than
the normal bleeding procedure.
I looked in the tech library but that all seems to detail with upgrades,
repairs & modifications, nothing about plain old ordinary bleeding.
Normally, the vacuum will pull the fluid thru without pushing the brake pedal
up and down.
What's the trick, or do I have something wrong somewhere?
Thanks for info - I need to get this thing back on the road this weekend.
up and down.
