Blazer lights not very bright
devinhal
I have two Blazer 6'' light on my front bumper. I have them wired with 14 gauge wire and they still won't put out much light. They are actually much dimmer than my stock headlights on the truck. I have 2 KC lights forked off of the same wire and they are extemely bright. Is the dim light due to the quality of the lights or is something else going on? Thanks
whats the wattage? and some cheap lights dont have the reflector design like some other good ones do.
May also be drawing too much power. I tend to agree that the reflector could be a factor. Check ground?
check the switch connections. once, I had reversed the connections on my switch, causing the lights to only put out about 25 watts.
