PuebloBroncoII
- Apr 9, 2008
- 1986 Ford Bronc
I have 86 Bronco II 2.9 engine. About two weeks ago I had a problem with the engine missing. I replaced the MAP sensor and solved the problem. Along the way i Also repalced the EGR valve and the IAC. After I fixed that it now idles perfect and tops out perfect but in between about 3000 rpm it misses bad and seems like its starving for gasor something, but if you push the gas to floor it straightens out. Also i notice when idling it shoots black soot from the tailpipe and has an odor like its running rich. I replaced the fuel filter as well. Any ideas of what this problem may be would be greatly appreciated.
