2 inch gen1? BL. its an 88 might be gen 2 then. 2 inch body lift, will i need to make custom bumper relocation brackets? so it dont look like crap?
I had to make a bracket for mine, it did kick the bumper out a little more (I had to notch it to go around the frame horns) I connected the two brackets with a peice of angle iron I welded two D rings onto, and then cut the factory airdam to fit.
BTW the first generation (like our trucks) went from 83-88, the second generation trucks went from 89-92.
My buddy actually cut the front bit of the frame horn off that the bumper bolts to and moved it up 2 inches and re welded them to the frame. Worked out really well.
