- Aug 6, 2007
- Age
- 62
- Automatic
Hello everyone!
Three days ago my truck started acting strangely. Despite setting the air solenoid to control fast idle speed at 1 500 rpm, it began fast idle at nearly 2 000 rpm. Once warmed up, the idle would drop a few hundred rpm, and when my foot was out of the throttle (like when sitting at a light), the fuel cut would come in (as it's supposed to) and the injectors would shut off until the rpms dropped to below 1 000. Then, of course, the computer would turn them on again.
This "hunting idle" behavior used to happen a lot with the factory computer when I had air leaks. My first thought was that I had a vacuum leak happening somewhere. I searched all over the engine, yet the only thing I found was that my PCV valve had blown off. (I noticed quite a bit of oil on the back side of the engine and thought: "Uh oh, what have I done now?") I cleaned the valve and reinstalled it, but the high idle persists.
Thinking that maybe my IAC valve had the bun, I pulled the wiring off. Nothing happened. It's as if the IAC valve doesn't exist!
Now that's REALLY strange, because I've got the throttle stop closed and the IAC is controlling my idle. I'm thinking that maybe my IAC valve has clogged and is stuck "open." I have to check that, but I don't have time right now.
So before I become completely frustrated with my truck, do any of you have any ideas for me? How do you track down an elusive vacuum leak?
