1983dieselranger
I have got a 1994 Ford Ranger Ext Cab 4x4 and i just installed a set of warn manual hubs with the conversion kit. The instructions with the conversion kit said to install the 3 piece thrust washer set that was already on the truck with the automatic hubs. My truck never had the 3 piece thrust washer set in either side! All i had was the retaining ring and the first metal thrust washer that had the cut outs in it to slip over the splines in the axle. I took it for a drive and when i made a turn in gravel it started popping and got bound up like the front end was fighting against the rear end. The instructions with the manual hubs says all i need is that first thrust washer with the cutouts in it and the retaining ring. Seeing how that was all i had thats all i installed. Maybe thats whats wrong. Any suggestions?
