Billy Cranston
- May 16, 2022
- San Diego
- 4.0 V6
- Automatic
- Tire Size
- 31"
- My credo
- ~ Certified Glue Eater
Hey all, figured I'd drop my Ranger and update as I work on it. I plan to keep it 99% stock, I just want to do maintenance, keep it running and looking nice.
This is the condition I picked her up in. 190k miles with a poorly fit camper shell, no Alcoa Wheels & a host of problems (including a failing wheel bearing) I've been working through.
What I've done so far: removed the shell, swapped the wheels, replaced the RF hub assembly, the starter and then driver side valve cover gaskets and an oil change.
I'm going to refurbish the running boards, change out a bunch of gaskets and seals, replace the front suspension, shackles and hangars, OEM lights... A new passenger side door... Pretty much going to change out the whole car
