- Feb 25, 2010
- GA via NC Mtns.
- 4.0 V6
- Total Lift
- 4"
- Tire Size
- 31X10.50
Okay I have the 90 BII 4WD with a 92 4.0 manual drivetrain-M50D. Has anyone installed the 93 and newer updated clutch slave cylinder with the larger bore connector for the line assembly? If so, what year clutch master cylinder and vehicle did they use to get it to work with the BII or is this a possibility? Thanks ahead for your input. I hope I did not make a decision here that will not work. I do a lot of things by the on the fly method.
