BII Driveshaft Vibrations
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
UT
So....I've got about 5" of lift on the BII, and I'm having some serious drivehsaft vibrations that I cannot get rid of. This is the third BII I've had with this much lift, but it's the first one with any problems....
I've got a single carden driveshaft, I have the transfercase and pinion flanges parralell, at the same angle, the u joints are nice and tight...I'm baffled.
On the highway, above 55mph, it vibrates the tranny and t case, and I can feel it in my feet. From about 35mph and down, it sounds like I have cards in my spokes on a bicycle...And I know for a fact it's the driveshaft, and not the tranny, tcase or rear end.
:icon_confused:
Single cardan...? You mean like this:
Or a single joint shaft like this:
If you have the top shaft, (a double cardan) the diff is supposeed to point at the t-case inline with the driveshaft.
If you have a single u-joint shaft, you are probably at the angular operational limits of the joints and need to swap to a double cardan shaft. (the top one)
I have a single joint shaft, and 5" of lift, and I get a little vibe at those speeds. I also have a C4 trans so my driveshaft is likely longer than yours, and thus the angles are less... so I can get away with it.
Assuming the angle isn't enough to bind the u-joints, remove the shaft and have it balanced.
Also, Ive actually installed U-joints TOO tight before and caused some tough vibrations. I'm not sure if they would have eventually worked themselves loose or not - Got that sucker back on the vise quick.
Agreed on the double-cardan driveshaft. These things are short enough a DC shaft is pretty much mandatory with any lift.
The "cards in the bicycle spokes" part sounds more like a bad u-joint or something wrapped up in the driveshaft though :icon_confused:
I have the single joint shaft.
I figured it was time to hunt down a double carden, but I have run that same shaft and the same lift with no problems, so I was a little :icon_confused:
Yeah, That's what I am thinking, but there is not...:icon_confused:
This has been puzzling me for about a month now, I've swapped driveshafts, messed with the pinion angle, made sure it wasn't the tranny/t case....driving me crazy!
I'm going to go find a DC shaft. Thanks brotha's!
:icon_welder:
Update:
DC shaft took care of all the issues. Thanks guys!
I used a front 1354 output yoke on the back of the TC, and used a front BII shaft shortented about an inch and a half. Works like a charm! :icon_thumby:
No problem. Glad to hear you got it fixed :icon_thumby:
