Bigger tire question?
my03ranger
SUBURBIA OF CHICAGO
I just got a 2" spacer lift put on with some new shocks and the truck is a little bit higher not much but def some room for bigger tires. I got 235/70/15s right now and was thinking about 30s or 31s! Now the question is if I were to get one of these tire sizes would I possibly rub against the control arm or anything? If I rub the bumper big deal, trimming could solve that problem but i just dont want to effect rubbing against anything else.
i have 6 inches of lift and 33's..i fully clear the 33's but still rub the radius arms so idk if theres anything to prevent it really.i may be wrong.
Spacer lift? Don't you have t bars? well I think 31's should fit... don't know though because my truck takes 31's but its a 4x4.
You can always take it to a shop and test fit the size you want they should mount one up and put it on the front and turn it full crank both ways to see if it rubs.
No T bars here, just coils. Wish I had T bars tho. I got the doetsch 2"spacers and their chart on their website says max 31x10.5x15 but it just seems so big! I dont know but I will see if I can get some test fitted, thanks for the idea'r
you will be able to fit 31s may rub a little with flex but street driving will be fine
