Beter Bed
RumpRangerSTX
Solid Axle Swap
mt holly nj
Have 87 Stx But Want A Stepside Bed The Splash Bed . Would It Fit On And Will The Body Line Macth Up. Has Anyone Done This If So Pics Helpful Thank U
Well, first of all, this has been discussed before.
If you want the body lines to match up, then you'd best not do the swap... The stepside is rounded, and your cab is square. And, the stepside is wider than your cab is, at the bottom. So the wheel openings and lower area would stick out more than you cab does.
I know I've seen pictures of one on here before, but I'll leave the searching up to you! I am pretty sure is was in the "Exterior" forum.
explorin94 had a second gen ex cab with a stepside bed and it didn't look to bad. but if you have a long bed it won't work anyway.
I remember seeing a Gen2 ranger, Red, HUGE ford ranger looked AWESOME. He had put a stepside on it, i liked it. Just cant remember his name or if his photos are in the gallery or not.
