Best tools you own
My Fluke Multimeter and Motive pressure bleeder.
Ahh, well, there’s that then. What good is being able to test AC if it won’t do 120v. Apparently the 4 does test injectors, not sure how helpful that would be though.
I just bought a III for my oldest daughters future husband. It was $109 on amazon. I also saw this when I was looking. It's really what the original Power Probe was when it was first released. I would still be using it but I lent it to a neighbor and it was brought back smoked.
Amazon.com: Power Probe Car 6V-24V DC Circuit Tester Polarity Test&Component Activation Electrical Tester Overload Protection Continuity Tester with LED Test Light Automotive Circuit Breaker Finder with 4M Lead : Automotive
As the Channelock dyke debate... I just bought a new pair off 449 high leverage dykes. My last pair got used for close to 30 years. I would still be using those... but since I moved they're non-existent.
For me, it's always harder to replace a lost tool that was perfectly fine before it disappeared and very easy to replace a broken one with a better/newer model/brand
Dang... I just looked and this Power Probe III is only $92.99.
That's the best price I've seen. No case or accessories... just the base tester.
I should just send the one I bought back and order this one for $17 less. In fact for $17.... I'm gonna.
Why not just buy two? Also loosing money not.
~ Klein "Dykes"; now 30+ years old; never sharpened & still easily cuts an 1/8" steel nail;
had to re-insulate handle with ElectricTape+HeatShrink for occassional work on live wires;
used daily; don't advise using handle as pry bar.
~ NeedleNosePliers; now 30+ years old; don't know the brand as its been worn off; used daily;
again had to re-insulate handle.
~ ViceGrips (OriginalBrand+Version & NeedleNose version); inherited from Dad; 50+ years old now;
had to re-tightened HingePins once or twice, but otherwise great tools; used daily.
~ Fluke DigitalMultiMeter; now 30+ years old; excellent quality; needs a fresh 9vBattery about every 10 years.
~ 1/2"Ratchet + 1/2"x3ftTorqBeam SearsCraftman, again inherited from Dad & 50+ years old; good tough tools.
~ A variety of Funnels for filling Oil +Coolant +Brake +Tranny fluids; stupid basic tools; any brand will do.
EDIT... forgot the link.
Amazon.com: Power Probe III Clamshell - Fire (PP3CSFIRE) [Car Automotive Diagnostic Test Tool, Digital Volt Meter, AC/DC Current Resistance, Circuit Tester] : Tools & Home Improvement
Don’t get the camo one... I have it and I can never find it.
69384
Then I would have to (A) carry a small pry bar AND the dykes up a ladder, or (B) make extra trips up & down the ladder to get the job done.
It's really more of a "multi-tool" than "just a pair of dykes" I've pulled nails with them, and also drove nails in with them. Used them as a lever to level a frame to a house and use them as a wedge to separate a frame from a house. I use the handle to pry open the aluminum "C channel" so the fabric will slide in without catching the corners. Believe me when I say, I NEED these things to get sh!t done.
Might I suggest "pockets".
I just exchanged a very old Snap-on dykes for a new pair...I really liked the old ones but they were just dull and the jaws were trashed. These are hands down the nicest ones I've ever had. In fact I may never use them for metal - they cut zip ties off so perfectly flush, I am almost scared to mess them up.
Sounds like you need to try a pair of fencing pliers.
69393
Or whatever this thing is.
69392
Flush cutters. few different companies make them. Small and light to get into tight spaces. Cuts the zip tie perfectly flush with the end of the square part.
