I have 2 3.0 rads at home but both are for a auto. I'm sure they would still work.( I would double check) If your interested I would sell one for a good price.
I've got a 98 3.0 m/t with 1 pass that won't over heat on a 100+deg. day with the A/C on Max. ( shuts off Heater Core ) , it's the origonal just Keep the Cooling System Clean
Drain & Flush at least every 2yrs. as the newer vehicles make Mud in the system , change the Thermostat also and don't buy a Cheep one either , check your fan clutch & fan - fans will stress crack over the years then BLOW UP. also the heater core may plug or start to leak and thats a 8hr. job if you haven't done it before , I've done 2 & they are NO FUN.
For
