- Jan 23, 2010
- ND
- Total Lift
- 2" body. 1.5" coil spring spacers/rear block
I'm in the process of gutting and redoing the floor on my 84 BII and I've decided to give up on the carpet. First I'm going to POR-15 the whole floor and use some rubberized sound and heat insulation spray I found at Fleet Farm in the foot areas. On top of that I'd like to put some bed liner, preferably a roll/brush on type since I'm too lazy to do a lot of masking and don't want to buy a special spray gun for it.
My question is, what have other people used and liked? I like the Line-X in the bed of my F-150 but don't want to shell out the hundreds of dollars for it for my BII. What I like about it is that it's fairly thick, durable, and somewhat soft (Rhino Lining is even softer but same cost issue). I did the floor of my dad's BII with Rustoleum Spray Can bed liner and it seems a bit harder and thinner than I'd like although the durability and toughness seems ok. I also have experience with Herculiner in my old Ranger bed, that stuff is tough enough to draw blood if you rubbed against it so I'd like to try something else.
I'm kinda leaning towards Rustoleum bed liner in the one gallon can (I can find it for $43 locally so it's fairly cost effective) and I know that being a roll on type I should have better control over the thickness of it compared to the spray can I used before (and being a gallon it should get plenty thick) or Dupli-Color Bed Armor ($75 from Amazon.com, Prime Eligible). I don't have any experience with this product so I'd be going in blind. Any other suggestions or experience with either of these products? I'd like to keep the cost under control, I know there are some great expensive products out there but I just don't want to spend them money on them, I'm already in this floor project for about $80 for the POR-15 so I'd like to keep it under about $100 for the bed liner including shipping.
