Burnsy
2001 3.0 v6 ranger.....when putting on new pads how important is it to bend in the tiny tabs on the clips that the pads slide into ? Im not talking about anything on the pad im talking about the clips/guides that the pad sits in.......theres tabs at the top and bottom, like two on top two on bottom, they seem designed to hold the pad in place ive heard people say you don't have to bend them in that the caliper will hold the pad in place............im getting a grinding from somewhere but its not pads/rotors in the classic sense...i changed my pads and rotors they're wearing normal but sometimes after I've gone ten miles with frequent stops, if I come to a quick stop, on the end of the stop I get this grind.......if I pull my foot off the break then reapply the noise goes away.....I should add my rear shoes need replacing bad according to my buddy....do the front and rear brakes work together ? Or could I be hearing my rear brakes ? I'm also thinking a sticking caliper but I'm not sure how that applies exactly to my problem........Before I get into new calipers I was wondering if those tiny tabs on the clips could be the culprit I don't push the tabs in when doing pads but never had a problem before......also, it's worse when pulling my lawn trailer, like there's more weight to stop, so its worse happens more frequently.......are my worn rear brakes making my fronts work too hard ? the sound is like bad pads on bad rotors, definite grind, but my new pads and rotors are wearing perfect , no wear no grind marks so in perplexed, .....could a pad be shifting without those tiny tabs pressed in on it and causing odd contact that would grind ? Thanks
