Josh222
- Jan 6, 2017
Looking at replacing the old worn out and finicky 4D55 Mitsubishi engine in my truck with the 1.9TDI out of my Jetta. The bell housing adapters available are made for the 3L and 4L engines. My truck currently has a FM145 transmission with which I assume is a 4D55 specific transmission bellhousing but this transmission was also used on the 2.9L V6. Is the bell housing bolt patterns the same between the 2.9L and 3L or 4L? If I end up needing to get a M5OD transmission from a 3L or 4L truck will the old BW1350 transfer case I have now bolt up to it so I can keep the mechanical speedo working.
