Been gone a long time
feellnfroggy
Knoxville, TN
But i finally got the green beast back from florida. My left leaf has fallen 5 inches since i got the truck back in jan. I was lookin for a cheap option for 2 inch lift leaves, or replacement leaves. and i found this. maybe its posted here somewhere, but i wasnt sure. Hope yall like it.
http://www.generalspringkc.com/index.php?p=product&id=1465&parent=68
feeln_ I added a couple more things that I needed to your basket...I'll forward your springs to you......
;missingteeth;
Welcome back...
Are you sure it's not the shackle? Common problem with Rangers...just had my passenger side done...must have been those 700 lb loads of cat dung...really~!
its not the shackles, the shackle mount is weak and slightly bent, but its from me beatin the shit outta it off road with weak springs. Its the driver side spring which has alot of ranger lean, but a good spring wouldnt flatten out that bad with just a shackle problem. Its the strength of the spring htat holds the shackle in place anyways, not the other way around.
