malecat
- Feb 26, 2008
- Age
- 60
I have searched all over this site and all over the internet too and cannot find the answer to this question. Can anybody tell me for sure about the bearing-bushing issue on the newer 29071 hubs? Do the newer 29071's have bearings or bushings? I have a 1996 ranger that I want to replace the broken automatic hubs. In reading the "Offroad Tech" article by 4x4Junkie "Stronger "Jeep" hubs for the Dana 35" it tells of using P/N 37780 Jeep hubs in place of the stock replacement P/N 29071. The 37780's are only $20.00 more than the 29071's for sale on this site. If you look closely at the pictures in the article, the 29071's have a huge needle bearing that covers the whole length of the axleshaft gear. It will probably last for a long time. The 37780's have a small bushing that doesn't even cover the full length of the bearing surface of the axleshaft gear. I drive my Ranger cross country and bushing wear is a concern. The Jeep hubs are stronger but how often would you drive with the rear hubs unlocked on a Jeep. Probably only for towing and thing likes that so bushing wear would not be an issue. I have also looked on Warn's site and they do not show a service kit for the 37780's. If both the 37780's and the newer 29071's both have a thin bushing, I will spend the extra $20.00 and go with the 37780's. But if the 29071's still have the needle bearings I will probably go with them. Can anybody answer this question? Does anybody know the answer? I have seen this question come up several times before on forums and nobody ever gave a definitive answer......
