bearing diameter
86ford
rocky river ohio
ok i am in the middle of swaping in my d35 to replace the d28 on my b2. i currently have new wearever brake rotors part number yh141265. the bearings i purchased are larger than the ones that are intended for this rotor. i need to know the proper bearings so that i can put this together.
86
i do realize this is a double post but i am unshure of whom on this forum is cappable of assisting me with my current issue.
What year is your D35 from? Single or dual piston calipers?
Its common for the parts guy to give you the wrong rotors because of the way its listed in the catalog on their computer, unless of course they are firmiliar with rbvs. I do believe the rotors he gave you are for the D28.
If you have a 90-94 D35 w/o ABS, the part number you need is YH141860.
If you have a 90-94 D35 w/ 4WABS, the part number you need is YH141900.
If you have a 95-97 D35, the part number you need is YH145059.
The wheel bearings you need are National A37, for both inner and outer. Dont forget to replace the wheel seal while your at it.
Or Timken SET-37.
