beadlocks for prerunner?
sports5
Im building a ranger prerunner and I wanted to know if prerunner necessary have to have bealocks or are the beadlock only for rockcrawlers?
Any time you plan on driving aggressively beadlocks will come in handy.
Crawlers - Push the bead off running into rocks and running low sigle digit air pressure.
Prerunner - Knock beads off in high speed turns, rolling the sidewalls over and burping air on impacts (rocks/ledges etc)
Drag racers - Spin rims inside tires on hard launch's with slicks.
what about maintenance ? What do you have to do to them?
Depends on what kind you go with:
Bolt on style you have to check the bolt torque regularly.
Inner air you have to check the tube for proper air pressure.
Some are, some aren't....You can get an aluminum DOT approved bolt on beadlock but they're big $$$. The inner air locks don't have a DOT approval, but they don't need it as all the are essentially is an inner tube... just gotta drill a second valve stem hole in the rim.
My Ranger (87) has been a prerunner/chase rig nearly since new. I have owned it since 2000. I prerun, chase and have run some pretty serious Poker runs with it and in the last 11 years have never had a flat not caused by a puncture (one staple and one screw). I also don't plan to buy beadlock wheels for it when we race it. Only if we start having flats will I reconsider. In my opinion spend the money elsewhere.
I do some co-driving in a race truck with out beadlocks and it does great. In my opinion beadlocks are the last thing that you need to buy
