- Nov 27, 2008
- central IL
- State - Country
- IL - USA
- Drive
- 2WD
- Automatic
- Total Lift
- 6+3
- Tire Size
- 33/12.50/15
I have found several problems and repaired them. The battery was load tested by a battery place and was good. I cleaned the battery terminals and had to replace the end of the positive cable. I found the starter wire end was broken in half, put new end on it. It the light is still on. The meter shows it is charging in normal range. It doesn't seem to want to start, very slow at turning over. It runs rough when it starts. I tested at the battery negative post between the cable and the post with a meter to see if it read any voltage, the way to check for a short. I did that with the key on and with it off. What else would cause the problem? What else should I check?
