banging/thud noise when driving over pothole
misterW
Seems to be coming from front left side. Front has new shocks....what should I check/what are most likely causes?
Check your ball joints, specifically the seals to see if they're rotted away. If they are, then all the grease has escaped and they will get noisy
If it didn't bang before, check shock installation.
Richard
mine did it when the camber was really messed.
check if the tires are aligned properly and check the ball joints. mine broke the upper joint because of the alignment issue.
