DrDirty
- Jun 12, 2014
- Automatic
Hello,
I am drawing st straws now with a problem i am having with one of my rangers, it is a 98, 3.0 5 speed
Problem is misfire on cyl 5, cylinder has compression, spark, but no fuel. injector does not fire
I first replaced the injector, which did nothing
then tried a noid light, and sure enough no fire
checked all wiring, i get the 12 volts through the injector all the way back to the PCM
What i do not get is the ground trigger the pcm is supposed to put out to fire the injector.
I have tried 3 different computers, i cant believe i have 3 computers with bad injector 5 drivers..
I replaced both the cam and crank sensors
Pulling my hair out, does anyone have any ideas why this could happen? if so please help
