Ball joints ??
desi
2001 Ford Ranger
2.3 liter 5 speed
195k miles
Hello ,
I was told there is a bit of play in my front passenger side tire. I had this ball joint done 20k-30k miles ago about 2 yrs back. Is there a way to tighten and or pack with grease to tighten or should I just have it replaced? I need to get an inspection sticker.
Secondly, the e-brake handle has a coil spring that connects to the flange. Spring end is hooked and this hook broke. I am bending another hook from the spring and will attempt to put spring back in place. Will this work or do you have another suggestion?
Thanks in advance
