Starting to run down some more issues on my '86 BII. Not having a CEL has it's ups and downs. No light makes it easy to ignore an unhappy system.
Current codes are
18 - SPOUT
32 - EGR pressure
89 - Ignore. Swapped to 5spd from auto.
For the most part this thing runs great. Sometimes when it's cold it stumbles a little bit when I give it light throttle but not always. Again when; cold sometimes it idles down pretty quick and acts normal. Sometimes it likes to hold high idle until it builds heat. Again not all the time. Only issue I've noticed when warm is after decelerating in gear it will buck and stumble when I apply throttle but clears up and goes like normal. Hot idle is pretty steady. Other issue (related?) is the tach sometimes will read very high. The issues don't seem to be in time with each other so I assumed the tach itself was going bad. Is there any chance the code 18 and weird stumble could be caused by the tach going bad or would the tach reading off be a symptom of a bad pickup in the distributor?
I went through the testing procedures I found online for the code 32 and the sensor seems to be open on the feedback side so I'll get one ordered tonight.
Current codes are
18 - SPOUT
32 - EGR pressure
