spdcrazy
- Mar 8, 2008
- Age
- 37
- Homer, alaska
- mostly 86
obviously i cant tell you its a thunk, or a crunch, or a tap tap sound and you tell me what it is, but i'm having a repetitive sound from the front right aread on my b2. i do think i'm getting it in 2wd as well as 4wd, and usually when the suspension is flexing a bit, its not a brake line hitting the spring but thats what it sounds like. i was thinking maybe the hub, but it isn't constant and it does it in 2 and 4wd. any thoughts of things to check?
also didn't seem to make a difference if the wheel is cut to the left or right, happens on hard whoops and bumps and the like
